Zum Hauptinhalt wechseln
Dell Latitude 5480 Display Replacement
Was du brauchst
  1. Dell Latitude 5480 Display Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Display Replacement: Schritt 2, Bild 1 von 3 Dell Latitude 5480 Display Replacement: Schritt 2, Bild 2 von 3 Dell Latitude 5480 Display Replacement: Schritt 2, Bild 3 von 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Display Replacement, Battery: Schritt 3, Bild 1 von 2 Dell Latitude 5480 Display Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the four 5.6 mm Phillips screws that secure the battery.
  4. Dell Latitude 5480 Display Replacement: Schritt 4, Bild 1 von 3 Dell Latitude 5480 Display Replacement: Schritt 4, Bild 2 von 3 Dell Latitude 5480 Display Replacement: Schritt 4, Bild 3 von 3
    • Lift the battery up and out of the chassis.
  5. Dell Latitude 5480 Display Replacement, Display: Schritt 5, Bild 1 von 3 Dell Latitude 5480 Display Replacement, Display: Schritt 5, Bild 2 von 3 Dell Latitude 5480 Display Replacement, Display: Schritt 5, Bild 3 von 3
    • Insert a plastic card between the bezel and the display.
    • Slide the plastic card beneath the entire bezel to sever the adhesive that secures the bezel.
    • Lift the bezel off of the display.
  6. Dell Latitude 5480 Display Replacement: Schritt 6, Bild 1 von 3 Dell Latitude 5480 Display Replacement: Schritt 6, Bild 2 von 3 Dell Latitude 5480 Display Replacement: Schritt 6, Bild 3 von 3
    • Remove the four 5.6 mm Phillips head screws, one at each corner, to release the display assembly.
    • Gently lift away the display panel and set it on top of the keyboard.
    • Take care not to strain the display assemble cable.
  7. Dell Latitude 5480 Display Replacement: Schritt 7, Bild 1 von 3 Dell Latitude 5480 Display Replacement: Schritt 7, Bild 2 von 3 Dell Latitude 5480 Display Replacement: Schritt 7, Bild 3 von 3
    • On the bottom of the back of the display panel, remove the tape that secures the cable connecting the screen to the base of the computer.
    • Flip up the display cable locking bar.
    • Disconnect the display connector.
    • Remove the display.
Abschluss
University of Memphis, Team 2-2, Sneed Spring 2024 Mitglied von University of Memphis, Team 2-2, Sneed Spring 2024
UM-SNEED-S24S2G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 29
Insgesamt: 53
