Zum Hauptinhalt wechseln
Dell Latitude 5480 Power Jack Replacement
Was du brauchst
  1. Dell Latitude 5480 Power Jack Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Power Jack Replacement: Schritt 2, Bild 1 von 3 Dell Latitude 5480 Power Jack Replacement: Schritt 2, Bild 2 von 3 Dell Latitude 5480 Power Jack Replacement: Schritt 2, Bild 3 von 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Power Jack Replacement, Dell Latitude 5480 Battery Disconnection: Schritt 3, Bild 1 von 2 Dell Latitude 5480 Power Jack Replacement, Dell Latitude 5480 Battery Disconnection: Schritt 3, Bild 2 von 2
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  4. Dell Latitude 5480 Power Jack Replacement, Power Jack: Schritt 4, Bild 1 von 3 Dell Latitude 5480 Power Jack Replacement, Power Jack: Schritt 4, Bild 2 von 3 Dell Latitude 5480 Power Jack Replacement, Power Jack: Schritt 4, Bild 3 von 3
    • Unscrew the right 3.7 mm screw that secures the fabric flap and the right side of the charging port bracket.
    • Carefully lift the flap out of the way of the left charging port bracket screw.
    • Unscrew the second 3.7 mm screw on the left side of the charging port bracket.
  5. Dell Latitude 5480 Power Jack Replacement: Schritt 5, Bild 1 von 3 Dell Latitude 5480 Power Jack Replacement: Schritt 5, Bild 2 von 3 Dell Latitude 5480 Power Jack Replacement: Schritt 5, Bild 3 von 3
    • Remove the metal bracket that secures the charging port.
    • Keep the fabric flap tucked out of the way.
    • Use the pointed edge of a spudger to push the charging port motherboard connector directly out of its port.
  6. Dell Latitude 5480 Power Jack Replacement: Schritt 6, Bild 1 von 1
    • Lift the entire charging port assembly up and out of the chassis.
Abschluss
University of Memphis, Team 2-2, Sneed Spring 2024 Mitglied von University of Memphis, Team 2-2, Sneed Spring 2024
UM-SNEED-S24S2G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 58
