Zum Hauptinhalt wechseln
Dell Latitude 5480 Speakers Replacement
Was du brauchst
  1. Dell Latitude 5480 Speakers Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Speakers Replacement: Schritt 2, Bild 1 von 3 Dell Latitude 5480 Speakers Replacement: Schritt 2, Bild 2 von 3 Dell Latitude 5480 Speakers Replacement: Schritt 2, Bild 3 von 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Speakers Replacement, Battery: Schritt 3, Bild 1 von 2 Dell Latitude 5480 Speakers Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the four 5.6 mm Phillips screws that secure the battery.
  4. Dell Latitude 5480 Speakers Replacement: Schritt 4, Bild 1 von 3 Dell Latitude 5480 Speakers Replacement: Schritt 4, Bild 2 von 3 Dell Latitude 5480 Speakers Replacement: Schritt 4, Bild 3 von 3
    • Lift the battery up and out of the chassis.
  5. Dell Latitude 5480 Speakers Replacement, Dell Latitude 5480 Battery Disconnection: Schritt 5, Bild 1 von 2 Dell Latitude 5480 Speakers Replacement, Dell Latitude 5480 Battery Disconnection: Schritt 5, Bild 2 von 2
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  6. Dell Latitude 5480 Speakers Replacement, Speakers: Schritt 6, Bild 1 von 3 Dell Latitude 5480 Speakers Replacement, Speakers: Schritt 6, Bild 2 von 3 Dell Latitude 5480 Speakers Replacement, Speakers: Schritt 6, Bild 3 von 3
    • Flip the motherboard to view the speaker cable connection on the underside.
    • Flip up the speaker cable ZIF locking flap.
    • Disconnect the touchpad ribbon cable.
  7. Dell Latitude 5480 Speakers Replacement: Schritt 7, Bild 1 von 3 Dell Latitude 5480 Speakers Replacement: Schritt 7, Bild 2 von 3 Dell Latitude 5480 Speakers Replacement: Schritt 7, Bild 3 von 3
    • Disconnect the speaker cable by pulling it directly out of its motherboard port.
    • Do not pull on the wires.
  8. Dell Latitude 5480 Speakers Replacement: Schritt 8, Bild 1 von 3 Dell Latitude 5480 Speakers Replacement: Schritt 8, Bild 2 von 3 Dell Latitude 5480 Speakers Replacement: Schritt 8, Bild 3 von 3
    • Carefully unseat the wire between the two speakers from the clips.
    • Lift the speakers up and out of the chassis.
Abschluss
Karston Salsbury
243 Reputation
2 Anleitungen geschrieben
University of Memphis, Team 2-2, Sneed Spring 2024 Mitglied von University of Memphis, Team 2-2, Sneed Spring 2024
UM-SNEED-S24S2G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 57
