Einleitung
If your laptop battery fails or no longer holds a sufficient charge you can easily replace it. This guide will advise you on how to replace the battery.
Was du brauchst
Remove the following ten T5 screws securing the lower case to the upper case.
Two will be 6mm, eight will be 3mm in length.
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case.
Remove the lower case and set it aside.
2 weitere Personen haben diese Anleitung absolviert.
