Was du brauchst
Remove the following ten screws securing the lower case to the upper case:
Eight 3.0 mm T5 screws
Two 4 mm T5 screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case to remove it.
Fast fertig!
Abschluss
