Was du brauchst
Avoid static discharge by grounding yourself using a wrist grounding strap or by touching a bare metal surface like a connector on the back of the laptop. Remove all of the power including the battery and power adapter.
Unscrew and remove the battery.
Unscrew and remove SSD from motherboard.
Disconnect then unscrew and remove audio circuit board.
Fast fertig!
Abschluss
