Zum Hauptinhalt wechseln
Dell Latitude 7390 Battery Replacement
Was du brauchst
  1. Dell Latitude 7390 Battery Replacement, Bottom Panel: Schritt 1, Bild 1 von 1
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 Battery Replacement: Schritt 2, Bild 1 von 3 Dell Latitude 7390 Battery Replacement: Schritt 2, Bild 2 von 3 Dell Latitude 7390 Battery Replacement: Schritt 2, Bild 3 von 3
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 Battery Replacement: Schritt 3, Bild 1 von 1
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 Battery Replacement: Schritt 4, Bild 1 von 2 Dell Latitude 7390 Battery Replacement: Schritt 4, Bild 2 von 2
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 Battery Replacement: Schritt 5, Bild 1 von 1
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 Battery Replacement, Battery: Schritt 6, Bild 1 von 1
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 Battery Replacement: Schritt 7, Bild 1 von 3 Dell Latitude 7390 Battery Replacement: Schritt 7, Bild 2 von 3 Dell Latitude 7390 Battery Replacement: Schritt 7, Bild 3 von 3
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 Battery Replacement: Schritt 8, Bild 1 von 1
    • Carefully lift the battery out of the laptop.
Abschluss
To reassemble your device, follow these instructions in reverse order with your replacement battery.
4 weitere Personen haben diese Anleitung absolviert.
Julia Blahut
303 Reputation
2 Anleitungen geschrieben
Clemson, Team 1-4, Hunter Spring 2022 Mitglied von Clemson, Team 1-4, Hunter Spring 2022
CLEM-HUNTER-S22S1G4
5 Mitglieder
7 Anleitungen geschrieben
2 Kommentare
Are there any videos for the 7390 with the smaller battery (42Wh) versus the larger one?
Kitty Kang - Antwort
It would be super helpful if the laptop was named correctly as the "Latitude 7390 2-in-1" and if the title and introduction of this article also named it as such. That is the one shown here and for which ifixit guides exist. The Latitude 7390 is the non-convertible version, its inside is slightly different compared to the one shown here and so far no guides exist as far as I'm aware.
Almariel - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 46
Letzte 30 Tage: 203
Insgesamt: 9,558
