Zum Hauptinhalt wechseln
Dell Latitude 7420 Display Replacement
Was du brauchst
  1. Dell Latitude 7420 Display Replacement, Back Case: Schritt 1, Bild 1 von 3 Dell Latitude 7420 Display Replacement, Back Case: Schritt 1, Bild 2 von 3 Dell Latitude 7420 Display Replacement, Back Case: Schritt 1, Bild 3 von 3
    • Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
    • Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
  2. Dell Latitude 7420 Display Replacement, Display: Schritt 2, Bild 1 von 3 Dell Latitude 7420 Display Replacement, Display: Schritt 2, Bild 2 von 3 Dell Latitude 7420 Display Replacement, Display: Schritt 2, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the three, 2 mm screws fastening the cable covers.
    • Remove both cable covers.
  3. Dell Latitude 7420 Display Replacement: Schritt 3, Bild 1 von 2 Dell Latitude 7420 Display Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to detach the coaxial cables from the Wi-Fi card.
    • Disconnect the remaining cables connecting the display assembly to the board.
  4. Dell Latitude 7420 Display Replacement: Schritt 4, Bild 1 von 3 Dell Latitude 7420 Display Replacement: Schritt 4, Bild 2 von 3 Dell Latitude 7420 Display Replacement: Schritt 4, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws securing the display hinges.
    • There are two screws to remove from each hinge.
    • Lift the base to pull the display assembly free.
  5. Dell Latitude 7420 Display Replacement: Schritt 5, Bild 1 von 1
    • Separate the display assembly from the base of the laptop.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
nuredinroba
209 Reputation
1 Anleitung geschrieben
Gateway, Team 1-2, Pee Spring 2023 Mitglied von Gateway, Team 1-2, Pee Spring 2023
GCC-PEE-S23S1G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 53
Insgesamt: 1,299
