Einleitung
Use this guide to replace the battery of the Dell Latitude 9410 2-in-1.
Failure to charge or inability to hold a charge may indicate a faulty battery. Check the troubleshooting page before moving forward with the battery replacement as there are other potential causes that are easier to address, such as a faulty charging port.
Was du brauchst
Use a Philips #00 screwdriver to remove the five 3mm screws that secure the battery.
Grip the battery cable near the plug and pull it straight out, in the direction of the cable.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
Just one question about the speaker ribbon glued to the battery (Step 7). I can't remove the ribbon from my battery. The glue is very strong. I've pulled firmly, and I'm worried about breaking the cable. Any ideas about how to loosen the glue without damaging the computer, perhaps by applying heat or some sort of solvent?
