Zum Hauptinhalt wechseln
Dell Latitude 9410 2-in-1 CMOS Battery Replacement
Was du brauchst
  1. Dell Latitude 9410 2-in-1 CMOS Battery Replacement, Base Panel: Schritt 1, Bild 1 von 1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 CMOS Battery Replacement: Schritt 2, Bild 1 von 2 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 CMOS Battery Replacement: Schritt 3, Bild 1 von 3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: Schritt 3, Bild 2 von 3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: Schritt 3, Bild 3 von 3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 CMOS Battery Replacement, CMOS Battery: Schritt 4, Bild 1 von 3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement, CMOS Battery: Schritt 4, Bild 2 von 3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement, CMOS Battery: Schritt 4, Bild 3 von 3
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 CMOS Battery Replacement: Schritt 5, Bild 1 von 3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: Schritt 5, Bild 2 von 3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Grip the CMOS cable as close as possible to the plug, and gently pull directly backwards, in the direction of the cables, until the CMOS cable disconnects from the motherboard.
    • If the cable is hard to pull out by hand, use tweezers to get a better grip on the cable connector.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 31
Insgesamt: 765
