Zum Hauptinhalt wechseln
Dell Latitude 9410 2-in-1 Motherboard Replacement
Was du brauchst
  1. Dell Latitude 9410 2-in-1 Motherboard Replacement, Base Panel: Schritt 1, Bild 1 von 1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 2, Bild 1 von 2 Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 3, Bild 1 von 3 Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 3, Bild 2 von 3 Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 Motherboard Replacement, Battery: Schritt 4, Bild 1 von 2 Dell Latitude 9410 2-in-1 Motherboard Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use a Philips #00 screwdriver to remove the five 3mm screws that secure the battery.
  5. Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 5, Bild 1 von 3 Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 5, Bild 2 von 3 Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Use a Philips #00 screwdriver to remove one 4.5 mm screw.
  6. Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 6, Bild 1 von 2 Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Grip the battery cable near the plug and pull it straight out, in the direction of the cable.
  7. Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 7, Bild 1 von 2 Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to gently move the speaker ribbon cable away from the bottom of the battery.
    • The ribbon cable is thin and fragile; handle it carefully.
    • The ribbon cable only needs to be moved so that the battery can be removed; do not completely remove the ribbon cable.
  8. Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 8, Bild 1 von 2 Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Lift the battery out with two hands.
  9. Dell Latitude 9410 2-in-1 Motherboard Replacement, Motherboard: Schritt 9, Bild 1 von 1
    • Use a Philips #00 screwdriver to remove the two 2 mm screws that secure the fan.
  10. Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Disconnect the two ribbon cables connected to the motherboard by lifting the black ZIF tab and pulling the ribbon cables free.
  11. Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Disconnect the two Wi-Fi card cables by prying them up and away from the press-fit connector.
  12. Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Disconnect the small black wire from the mother board by pulling in the direction of the cable.
    • Disconnect the black and red wire from the motherboard, also by pulling the direction of the cable.
  13. Dell Latitude 9410 2-in-1 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Use a Philips #00 screwdriver to remove the eight 3 mm screws that secure the motherboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 350
