Zum Hauptinhalt wechseln
Dell Latitude 9410 2-in-1 SSD Replacement
Was du brauchst
  1. Dell Latitude 9410 2-in-1 SSD Replacement, Base Panel: Schritt 1, Bild 1 von 1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 SSD Replacement: Schritt 2, Bild 1 von 2 Dell Latitude 9410 2-in-1 SSD Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 SSD Replacement: Schritt 3, Bild 1 von 3 Dell Latitude 9410 2-in-1 SSD Replacement: Schritt 3, Bild 2 von 3 Dell Latitude 9410 2-in-1 SSD Replacement: Schritt 3, Bild 3 von 3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 SSD Replacement, SSD: Schritt 4, Bild 1 von 3 Dell Latitude 9410 2-in-1 SSD Replacement, SSD: Schritt 4, Bild 2 von 3 Dell Latitude 9410 2-in-1 SSD Replacement, SSD: Schritt 4, Bild 3 von 3
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 SSD Replacement: Schritt 5, Bild 1 von 3 Dell Latitude 9410 2-in-1 SSD Replacement: Schritt 5, Bild 2 von 3 Dell Latitude 9410 2-in-1 SSD Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the 2 mm screw, loosening the bracket that covers the SSD.
    • Carefully lift the off the bracket.
    • The bracket is attached to the laptop and cannot be removed completely.
  6. Dell Latitude 9410 2-in-1 SSD Replacement: Schritt 6, Bild 1 von 3 Dell Latitude 9410 2-in-1 SSD Replacement: Schritt 6, Bild 2 von 3 Dell Latitude 9410 2-in-1 SSD Replacement: Schritt 6, Bild 3 von 3
    • Grip the SSD and pull directly backward until the SSD releases from its port.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 12
Letzte 30 Tage: 39
Insgesamt: 1,005
