Zum Hauptinhalt wechseln
Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement
Was du brauchst
  1. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement, Base Panel: Schritt 1, Bild 1 von 1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: Schritt 3, Bild 1 von 3 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: Schritt 3, Bild 2 von 3 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: Schritt 3, Bild 3 von 3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 4, Bild 1 von 2 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 4, Bild 2 von 2
    • Remove the protective film located at the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 2 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: Schritt 5, Bild 2 von 2
    • Use a Philips #00 screwdriver to remove the 2mm screw located above the wifi card.
  6. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: Schritt 6, Bild 1 von 1
    • Remove the black and white wires located above the wifi card using a blue, plastic spudger.
  7. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: Schritt 7, Bild 1 von 1
    • Remove the Wifi card from its slot in the motherboard.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 359
