Einleitung
Use this guide to replace the Wifi card of the Dell Latitude 9410 2-in-1. Dropped connections, slow internet speeds or inability to connect to the internet may indicate a faulty Wifi Card.
Was du brauchst
Remove the protective film located at the top left corner of the motherboard.
Use a Philips #00 screwdriver to remove the 2mm screw located above the wifi card.
Remove the black and white wires located above the wifi card using a blue, plastic spudger.
