Zum Hauptinhalt wechseln
Dell Latitude 9510 Battery Replacement
Was du brauchst
  1. Dell Latitude 9510 Battery Replacement, Base Panel: Schritt 1, Bild 1 von 1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Battery Replacement: Schritt 2, Bild 1 von 1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the eight screws securing the battery.
  4. Dell Latitude 9510 Battery Replacement: Schritt 4, Bild 1 von 1
    • Place a spudger behind a plastic tab on either side of the plug, then "walk" the connector out of its socket by gently pushing the plug toward the cables, alternating sides, until the connector releases.
    • Lift the battery up and out.
Abschluss
David Cauley
85 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 18
Letzte 30 Tage: 49
Insgesamt: 759
