Zum Hauptinhalt wechseln
Dell Latitude 9510 Fan Replacement
Was du brauchst
  1. Dell Latitude 9510 Fan Replacement, Base Panel: Schritt 1, Bild 1 von 1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Fan Replacement: Schritt 2, Bild 1 von 1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Fan Replacement, Speakers: Schritt 3, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws from the speakers.
  4. Dell Latitude 9510 Fan Replacement: Schritt 4, Bild 1 von 1
    • Use a spudger to gently lever the speaker connector out of its port.
    • Lift the speakers up and out.
  5. Dell Latitude 9510 Fan Replacement, Fan: Schritt 5, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the two 3 mm screws securing the fan.
  6. Dell Latitude 9510 Fan Replacement: Schritt 6, Bild 1 von 1
    • Place your fingernails behind the plastic tabs on the speaker's motherboard connector, then pull directly backwards, toward the wires, until the connector releases from its port.
    • Lift the fan up and out.
Abschluss
Adam Sholar
243 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 161
