Was du brauchst
Disconnect the coin-cell battery cable connector from the system board connector.
Remove the coin-cell battery from the system board.
When you replace the battery, insert it at a 30-degree angle under the clip with the positive (identified by a plus [+] symbol) side up, and then push it into place.
Fast fertig!
Abschluss
