Einleitung
The RAM is essential for a computer to function, and must be replaced if is found to be faulty.
Was du brauchst
Flip the laptop so that the battery is facing up, and the Dell logo is facing down on the surface the laptop is placed on.
Use a Phillips #00 screwdriver to remove the 3 screws that hold the L-shaped back panel down.
Pull on the outside tabs keeping the RAM stick in place.
The RAM should then pop out and can be easily removed by pulling away from the slot.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
