Zum Hauptinhalt wechseln
Dell Latitude D430 Wireless Adapter Replacement
Was du brauchst
  1. Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: Schritt 1, Bild 1 von 3 Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: Schritt 1, Bild 2 von 3 Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: Schritt 1, Bild 3 von 3
    • Flip the laptop so you are able to see the bottom.
  2. Dell Latitude D430 Wireless Adapter Replacement: Schritt 2, Bild 1 von 2 Dell Latitude D430 Wireless Adapter Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the three screws that secure the small "L" shaped backplate.
  3. Dell Latitude D430 Wireless Adapter Replacement: Schritt 3, Bild 1 von 1
    • Once all 3 screws have been removed, carefully remove the panel by grabbing the edges, and pulling up.
  4. Dell Latitude D430 Wireless Adapter Replacement: Schritt 4, Bild 1 von 3 Dell Latitude D430 Wireless Adapter Replacement: Schritt 4, Bild 2 von 3 Dell Latitude D430 Wireless Adapter Replacement: Schritt 4, Bild 3 von 3
    • Identify the two pins connecting the wireless adapter to the motherboard. (The wireless adapter will say WLAN on it.)
    • Carefully pull up on each pin and remove them from the wireless adapter.
    • Note that there are no wires/cables connecting the wireless adapter to the motherboard.
  5. Dell Latitude D430 Wireless Adapter Replacement: Schritt 5, Bild 1 von 2 Dell Latitude D430 Wireless Adapter Replacement: Schritt 5, Bild 2 von 2
    • Pull back on the two metal tabs holding the wireless adapter down.
    • After the two metal tabs are pulled, the card will pop up.
  6. Dell Latitude D430 Wireless Adapter Replacement: Schritt 6, Bild 1 von 1
    • Pull the wireless adapter out away from where it was connected.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 511
