Einleitung
This guide will show how to add RAM or replace existing RAM on the Latitude D600
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Find the battery
    • Find the battery
  2. Pull the tab to release the battery Pull the tab to release the battery
    • Pull the tab to release the battery
  3. Pull the battery out
    • Pull the battery out
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Find the panel underneath the microsoft product key sticker, the panel is labeled with an M Unscrew the single screw above the M
    • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
    • Unscrew the single screw above the M
  6. Pull off the panel to reveal the RAM RAM is held in by two tabs, pull each tab to the side and the RAM will pop up RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
    • Pull off the panel to reveal the RAM
    • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
  7. Once the RAM is popped up, slowly pull it out of the slot
    • Once the RAM is popped up, slowly pull it out of the slot
  8. To add or replace RAM, place the memory into the slot at an angle Make sure you line it up correctly If it is in correctly it should stay up at an angle by itself
    • To add or replace RAM, place the memory into the slot at an angle
    • Make sure you line it up correctly
    • If it is in correctly it should stay up at an angle by itself
    • Then push down in the middle until it clicks into place
  9. The RAM should be secured by the tabs where the two semi circles are on the RAM
    • The RAM should be secured by the tabs where the two semi circles are on the RAM
    • If it is not secure, just gently pull it out and try again, use the images to help you out
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
Joseph
1.427 Reputation
5 Anleitungen geschrieben
Almost perfect: easy; clear;
Herman - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 2,046
