Einleitung
Replacing the intel wireless card, available for around 5 dollars on ebay
Werkzeuge
Kein Werkzeug erforderlich.
  1. Find the battery
    • Find the battery
  2. Pull the tab to release the battery Pull the tab to release the battery
    • Pull the tab to release the battery
  3. Pull the battery out
    • Pull the battery out
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  5. Use your screwdriver to unscrew and lift up the panel on the right labeled with a C
    • Use your screwdriver to unscrew and lift up the panel on the right labeled with a C
  6. Pull off the two wires connected to the wireless card
    • Pull off the two wires connected to the wireless card
    • They should come off fairly easy
  7. Pull the two tabs away from the card and pull up on the intel card Then pull it away from the holding slot to remove it
    • Pull the two tabs away from the card and pull up on the intel card
    • Then pull it away from the holding slot to remove it
  8. When placing in your new wireless card, connect the two wires before inserting into the slot Then line it up, put the card in at an angle and push down so the side tabs lock it into place
    • When placing in your new wireless card, connect the two wires before inserting into the slot
    • Then line it up, put the card in at an angle and push down so the side tabs lock it into place
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
Joseph
1.427 Reputation
5 Anleitungen geschrieben
Hi,
dell latitude D600 Laptop
Can you please help me, I cant release my wireless card, by pulling the tabs on cards sides.?
It just doesn't release the card to pull out, is there any other way I can remove my card.?
Email me if you can .
robert.wilson407@ntlworld.com
Thanking you Rob
rob wilson - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 28
Insgesamt: 1,995
