Einleitung
Replacing the intel wireless card, available for around 5 dollars on ebay
Was du brauchst
Use your screwdriver to unscrew and lift up the panel on the right labeled with a C
Pull off the two wires connected to the wireless card
They should come off fairly easy
Pull the two tabs away from the card and pull up on the intel card
Then pull it away from the holding slot to remove it
Then line it up, put the card in at an angle and push down so the side tabs lock it into place
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Hi,
dell latitude D600 Laptop
Can you please help me, I cant release my wireless card, by pulling the tabs on cards sides.?
It just doesn't release the card to pull out, is there any other way I can remove my card.?
Email me if you can .
robert.wilson407@ntlworld.com
Thanking you Rob
