Einleitung
Replacing a defective fan will stop your computer from overheating, preventing damage and increasing the life of your computer.
Was du brauchst
Locate the laptop battery release button lock
Push the battery release in the direction of the arrow, and pull upward.
Use an opening tool or flat tool to remove the plastic cover above the keyboard.
Turn the computer over. Using an opening tool seperate the top cover from the rest of the frame.
Remove the 3.9 mm Philips #1 screw.
Unplug the fan cable.
Lift fan out of compartment to remove the fan.
2 weitere Personen haben diese Anleitung absolviert.
