Zum Hauptinhalt wechseln
Dell Latitude D610 Keyboard Replacement
Was du brauchst
  1. Dell Latitude D610 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Latitude D610 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Dell Latitude D610 Keyboard Replacement: Schritt 2, Bild 1 von 3 Dell Latitude D610 Keyboard Replacement: Schritt 2, Bild 2 von 3 Dell Latitude D610 Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Dell Latitude D610 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery from its compartment.
  4. Dell Latitude D610 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 3 Dell Latitude D610 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 3 Dell Latitude D610 Keyboard Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Use an opening tool or flat tool to remove the plastic cover above the keyboard.
  5. Dell Latitude D610 Keyboard Replacement: Schritt 5, Bild 1 von 2 Dell Latitude D610 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 3.9mm Philips #1 screws that are holding the keyboard in place.
  6. Dell Latitude D610 Keyboard Replacement: Schritt 6, Bild 1 von 2 Dell Latitude D610 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Using an opening tool, carefully release the keyboard from the case.
    • Making sure not to tear or damage the wires still connecting it to the laptop.
  7. Dell Latitude D610 Keyboard Replacement: Schritt 7, Bild 1 von 3 Dell Latitude D610 Keyboard Replacement: Schritt 7, Bild 2 von 3 Dell Latitude D610 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Carfully lift the key board.
    • Lift only about 3 - 4 inches so that the wires holding the keyboard do not get damaged.
    • Pull on the blue tab to unplug the keyboard.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Jordan Barham
459 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 6-24, Maness Winter 2014 Mitglied von Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 1,971
