Einleitung
Replacing a defective RAM component is pretty easy and can stop your computer from frequently crashing.
Werkzeuge
Ersatzteile
Locate the laptop battery release button lock
Push the battery release in the direction of the arrow, and pull upward.
Using two fingers, push the silver ends away from the RAM until the RAM is released.
5 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
This model has two RAM slots. The second one is under the keypad. Carefully remove the bezel at the top of the keypad, remove the two screws holding the keypad down, then remove the keypad to expose the second slot. This RAM slot is a little bit more difficult to get to than the one on the back of the laptop, but is still very easy to access and change out.
