Zum Hauptinhalt wechseln
Dell Latitude D620 Display Replacement
Was du brauchst
  1. Dell Latitude D620 Display Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
    Frag FixBot
    Kommentar hinzufügen
  2. Dell Latitude D620 Display Replacement: Schritt 2, Bild 1 von 3 Dell Latitude D620 Display Replacement: Schritt 2, Bild 2 von 3 Dell Latitude D620 Display Replacement: Schritt 2, Bild 3 von 3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
    Frag FixBot
  3. Dell Latitude D620 Display Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
    Frag FixBot
  4. Dell Latitude D620 Display Replacement: Schritt 4, Bild 1 von 1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
    Frag FixBot
  5. Dell Latitude D620 Display Replacement: Schritt 5, Bild 1 von 2 Dell Latitude D620 Display Replacement: Schritt 5, Bild 2 von 2
    • Once keyboard is out of the case, lay it face-down on the track pad
    Frag FixBot
  6. Dell Latitude D620 Display Replacement: Schritt 6, Bild 1 von 2 Dell Latitude D620 Display Replacement: Schritt 6, Bild 2 von 2
    • Using a small spudger, pull back on the black bar to release the blue lever
    Frag FixBot
  7. Dell Latitude D620 Display Replacement: Schritt 7, Bild 1 von 1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
    Frag FixBot
  8. Dell Latitude D620 Display Replacement, Display: Schritt 8, Bild 1 von 1
    • Detach cables that connect the display to the body of the laptop
    Frag FixBot
  9. Dell Latitude D620 Display Replacement: Schritt 9, Bild 1 von 1
    • Disconnect the black cable attached to the motherboard
    Frag FixBot
  10. Dell Latitude D620 Display Replacement: Schritt 10, Bild 1 von 2 Dell Latitude D620 Display Replacement: Schritt 10, Bild 2 von 2
    • Close the laptop lid
    • Turn the laptop over onto its backside
    • Unscrew the two screws shown in the picture using a #00 screwdriver
    Frag FixBot
  11. Dell Latitude D620 Display Replacement: Schritt 11, Bild 1 von 2 Dell Latitude D620 Display Replacement: Schritt 11, Bild 2 von 2
    • Face the laptop's back ports towards you
    • Unscrew the two screws labeled in the picture using a #00 screwdriver
    Frag FixBot
  12. Dell Latitude D620 Display Replacement: Schritt 12, Bild 1 von 1
    • Turn the laptop over again so it's right-side up
    • Open the display, and pull the display up and out of the laptop's body
    Frag FixBot
  13. Dell Latitude D620 Display Replacement: Schritt 13, Bild 1 von 1
    • Remove the circular rubber pads as outlined in the picture using a spudger
    Frag FixBot
  14. Dell Latitude D620 Display Replacement: Schritt 14, Bild 1 von 1
    • Unscrew the screws that were under the rubber circles using the #00 screwdriver
    Frag FixBot
  15. Dell Latitude D620 Display Replacement: Schritt 15, Bild 1 von 1
    • Carefully use a spudger to work around the edge of the screen to lift off the plastic cover
    • Be very careful while doing this as the plastic snaps easily
    Frag FixBot
  16. Dell Latitude D620 Display Replacement: Schritt 16, Bild 1 von 1
    • Remove the screws outlined in the picture
    Frag FixBot
  17. Dell Latitude D620 Display Replacement: Schritt 17, Bild 1 von 1
    • Carefully lift the LCD screen out of its casing
    Frag FixBot
Abschluss
19 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 24-35, Regan Spring 2010 Mitglied von Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Mitglieder
4 Anleitungen geschrieben
1 Kommentar zur Anleitung
Check out this replacement screen at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 61
Insgesamt: 33,942
