Zum Hauptinhalt wechseln
Dell Latitude D620 Keyboard Replacement
Was du brauchst
  1. Dell Latitude D620 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Dell Latitude D620 Keyboard Replacement: Schritt 2, Bild 1 von 3 Dell Latitude D620 Keyboard Replacement: Schritt 2, Bild 2 von 3 Dell Latitude D620 Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 Keyboard Replacement: Schritt 5, Bild 1 von 2 Dell Latitude D620 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 Keyboard Replacement: Schritt 6, Bild 1 von 2 Dell Latitude D620 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Miguel Wong
562 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 24-35, Regan Spring 2010 Mitglied von Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
Check out this keyboard at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 16,772
