Einleitung
Guide to removing the keyboard from the D620.
Was du brauchst
Locate the notch under the cover at the top of the keyboard
Using the spudger as a lever, lift the plastic covering
Carefully remove the rest of the covering from right to left
Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Check out this keyboard at a great price on bcdelectrostore.com
