Zum Hauptinhalt wechseln
Dell Latitude D630 Battery Replacement
  1. Dell Latitude D630 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Battery Replacement: Schritt 2, Bild 1 von 1
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
Abschluss
To install your new battery, follow the steps in reverse order and slide your new battery in.
12 weitere Personen haben diese Anleitung absolviert.
Justin Ng
142 Reputation
1 Anleitung geschrieben
Cal Poly, Team 6-1, Johann Winter 2013 Mitglied von Cal Poly, Team 6-1, Johann Winter 2013
CPSU-JOHANN-W13S6G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 29
Insgesamt: 9,319
