Zum Hauptinhalt wechseln
Einleitung
Use this guide to replace the battery in your Dell Latitude D630 or to remove it before performing other repairs.
  1. Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Using two index fingers, slide the battery latches outward.
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
Abschluss
To install your new battery, follow the steps in reverse order and slide your new battery in.
10 weitere Nutzer haben diese Anleitung absolviert.
Justin Ng
110 Reputation
1 Anleitung geschrieben
Cal Poly, Team 6-1, Johann Winter 2013 Mitglied von Cal Poly, Team 6-1, Johann Winter 2013
CPSU-JOHANN-W13S6G1
4 Mitglieder
9 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 7,544
