Zum Hauptinhalt wechseln
Dell Latitude D630 Hard Drive Replacement
Was du brauchst
  1. Dell Latitude D630 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 3 Dell Latitude D630 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 2 von 3 Dell Latitude D630 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 3 von 3
    • Position the closed laptop upside down.
    • Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
    • Do not unscrew this screw!
  4. Dell Latitude D630 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Place thumb on the hard drive cover and get a firm grip.
    • Pull the hard drive out slowly to avoid any further damage to the laptop.
  5. Dell Latitude D630 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Dell Latitude D630 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the screw on the right side to remove cover.
    • Slide cover off.
Abschluss
17 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 1-4, Cichon Spring 2014 Mitglied von UMass Dartmouth, Team 1-4, Cichon Spring 2014
UMASSD-CICHON-S14S1G4
3 Mitglieder
1 Anleitung geschrieben
4 Kommentare
Dell latitude 2RHczd1
C Chandler - Antwort
Thank You Sir !
Bartłomiej Be - Antwort
I appreciate the guide my good sir. Very helpful.
Matt Erti - Antwort
Is the hard drive replaceable to 2.5-inch SSD? for example Kingston a400.
Aduh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 37
Insgesamt: 15,425
