Einleitung
Introduction
The hard drive is where you store permanent files on your laptop. If your hard drive is damaged and does not operate properly any more, or you simply want a larger and/or faster one, you can replace it with a new one.
This guide will teach you
- Where the Hard Drive is located
- how to remove safely
- Tools needed to complete the replacement
Was du brauchst
Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
Turn the laptop over so its bottom is facing you.
Using two index fingers, slide the battery latches outward.
While still holding the latches out, use your thumbs to slide the battery out towards you.
Once the battery is dislodged, you can let go of the latches and remove the battery.
Position the closed laptop upside down.
Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
Do not unscrew this screw!
Place thumb on the hard drive cover and get a firm grip.
Pull the hard drive out slowly to avoid any further damage to the laptop.
17 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
Dell latitude 2RHczd1
Thank You Sir !
