Zum Hauptinhalt wechseln
Dell Latitude D830 Battery Replacement
Was du brauchst
  1. Dell Latitude D830 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient the laptop so the opening is facing you.
  2. Dell Latitude D830 Battery Replacement: Schritt 2, Bild 1 von 1
    • Flip the laptop over, so the opening is still facing you.
  3. Dell Latitude D830 Battery Replacement: Schritt 3, Bild 1 von 1
    • Place finger/ thumb on the slide button, then push the button forward
    • This unlocks the battery.
  4. Dell Latitude D830 Battery Replacement: Schritt 4, Bild 1 von 1
    • Place finger/thumb under the ledge.
  5. Dell Latitude D830 Battery Replacement: Schritt 5, Bild 1 von 1
    • Lift up the ledge, this allows the battery to be removed.
  6. Dell Latitude D830 Battery Replacement: Schritt 6, Bild 1 von 1
    • The battery is now removed.
  7. Dell Latitude D830 Battery Replacement: Schritt 7, Bild 1 von 1
    • To insert a new battery, orient the battery with the battery opening.
  8. Dell Latitude D830 Battery Replacement: Schritt 8, Bild 1 von 1
    • Insert the new battery with the left side being placed in first.
    • Press the new battery down until a "click" is heard.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 420
