Was du brauchst
Slide any tool with a flat surface under the side bottom right corner of front panel and pry the front panel out of place.
Once out of place, position your thumbs under the bottom of the panel and pull upwards.
Use a flat head screwdriver to flip the keyboard connector up. This will allow you to disconnect the keyboard and remove it.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
