Einleitung
Follow the guide steps in order to remove the computers front panel successfully. It is essential for removing the keyboard and accessing other components located on the front of the main board.
Was du brauchst
Slide any tool with a flat surface under the side bottom right corner of front panel and pry the front panel out of place.
Once out of place, position your thumbs under the bottom of the panel and pull upwards.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
