Einleitung
Follow these steps in order to successfully replace the SSD of your laptop.
Was du brauchst
Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
Place thumbs flat on the front side of the back panel (the side to open the laptop).
Push panel upwards sliding it out of the locked position.
Lift panel out of socket.
Remove panel and screw from the device. This opens up the main board of the device.
Using your finger and thumb lift the hard drive out of the computer but do not disconnect the attached connector to the computer.
By applying pressure to the sides of the connector, pull the connector apart from the SSD.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
You can use any mSATA SSD as replacement by using the following caddy/adapter:
