Zum Hauptinhalt wechseln
Dell Latitude E4300 Keyboard Replacement
Was du brauchst
  1. Dell Latitude E4300 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Open the laptop and remove the small panel located above the keyboard.
  2. Dell Latitude E4300 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
  3. Dell Latitude E4300 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Pull off keyboard forward and then outwards.
    • The keyboard is fragile, so make sure you pull the keyboard off carefully.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 650
