Zum Hauptinhalt wechseln
Dell Latitude E4310 Display Replacement
Was du brauchst
  1. Dell Latitude E4310 Display Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power down the laptop and remove all power cords.
  2. Dell Latitude E4310 Display Replacement: Schritt 2, Bild 1 von 2 Dell Latitude E4310 Display Replacement: Schritt 2, Bild 2 von 2
    • Push in the battery release button with your thumb.
    • Pull up on the battery to remove.
  3. Dell Latitude E4310 Display Replacement, Display: Schritt 3, Bild 1 von 3 Dell Latitude E4310 Display Replacement, Display: Schritt 3, Bild 2 von 3 Dell Latitude E4310 Display Replacement, Display: Schritt 3, Bild 3 von 3
    • Open up the laptop and flatten it down on a workable surface.
    • Turn it around so that the screen is closest to you.
    • Insert the flat end of a spudger, or plastic opening tool, into the groove between the screen bezel and top case.
    • Twist the spudger, or plastic opening tool, until you hear a clicking sound and continue doing this around the entirety of the display.
    • Remove the bezel.
  4. Dell Latitude E4310 Display Replacement: Schritt 4, Bild 1 von 2 Dell Latitude E4310 Display Replacement: Schritt 4, Bild 2 von 2
    • Remove the six 0.3mm Phillips #1 screws.
  5. Dell Latitude E4310 Display Replacement: Schritt 5, Bild 1 von 2 Dell Latitude E4310 Display Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 0.5mm Phillips #1 screws.
    • There are two screws located at each corner. Only remove the ones closest to the outer edge.
  6. Dell Latitude E4310 Display Replacement: Schritt 6, Bild 1 von 2 Dell Latitude E4310 Display Replacement: Schritt 6, Bild 2 von 2
    • Carefully lift the screen up and flip it over onto the keyboard side as if you were turning the page of a book.
  7. Dell Latitude E4310 Display Replacement: Schritt 7, Bild 1 von 3 Dell Latitude E4310 Display Replacement: Schritt 7, Bild 2 von 3 Dell Latitude E4310 Display Replacement: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of tweezers to flip the blue tape 180 degrees.
    • By flipping the tape you disconnect the display connector.
  8. Dell Latitude E4310 Display Replacement: Schritt 8, Bild 1 von 1
    • Remove the screen from the laptop.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Aylin
309 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 19
Letzte 30 Tage: 22
Insgesamt: 1,619
