Einleitung
Although many people will discard a laptop without a working keyboard system, it is possible to replace at home. Keyboards are vital to being able to operate and type on a computer. A keyboard which needs to be replaced may have one or more key which is sticking or otherwise ineffective. This guide will show you how to replace a Dell Latitude E5410 keyboard in four simple steps.
Was du brauchst
Position laptop so that the LCD screen is aligned directly flat and parallel to the keyboard section of the laptop.
Use the iFix it Opening Tool to remove the flat section located directly above the keyboard, as seen in picture.
Locate two internal screws (pictured) under removed section.
Use the Phillips screwdriver to remove both screws.
Firmly grip the upper section of the keyboard.
Pull on the keyboard in an upwards motion.
The keyboard should be successfully removed.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
thanks man but its super easy not moderat i have 16 years old and i remove my keybord...
