Was du brauchst
Use your thumb to move the tab to the right that releases the battery, while using your other hand to slide the battery out.
The battery will come out straight toward you.
After removing the battery., loosen the screw(s) that secures the access panel to the computer, then that secures the access panel to the computer.
Locate and move the screws securing the hard drive to the computer.
Slide the hard drive towards the center of the computer and remove.
Remove the screws securing the hard drive caddy to the hard drive. Then, lift up the hard drive caddy at an angle from the hard drive and remove.
With your replacement hard drive , reassemble your device by performing these instructions in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
Angehängte Dokumente
2 Kommentare
Hi Mr. Thomas
I am using Dell inspiration can I install Samsung MZ1LB1T9HALS-00007 in my system using this method?
Hi Aaron Thomas
I am using Dell inspiration 15 can I replace my hard drive Western Digital WD40EFRX using the same method?
