Einleitung
This guide will show you how to replace a screen on the Dell Latitude E5410.
Was du brauchst
Have your laptop ready with your screen pulled all they way down parallel to the bottom of the laptop.
Start on the top left or right corner of the screen edge and unscrew the small screws.
Be sure to remove the rubber placeholders in order to access the screws.
Use the Phillips screwdriver to remove the screws from corners around the screen.
