Zum Hauptinhalt wechseln
Dell Latitude E5410 keyboard Replacement
Was du brauchst
  1. Dell Latitude E5410 keyboard Replacement, Dell Latitude E5410 keyboard: Schritt 1, Bild 1 von 1
    • Position laptop so that the LCD screen is aligned directly flat and parallel to the keyboard section of the laptop.
  2. Dell Latitude E5410 keyboard Replacement: Schritt 2, Bild 1 von 1
    • Use the iFix it Opening Tool to remove the flat section located directly above the keyboard, as seen in picture.
  3. Dell Latitude E5410 keyboard Replacement: Schritt 3, Bild 1 von 1
    • Locate two internal screws (pictured) under removed section.
    • Use the Phillips screwdriver to remove both screws.
    • The screw in the middle is 3.85mm and the screw on the left is 8.66mm.
  4. Dell Latitude E5410 keyboard Replacement: Schritt 4, Bild 1 von 1
    • Firmly grip the upper section of the keyboard.
    • Pull on the keyboard in an upwards motion.
    • The keyboard should be successfully removed.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
thanks man but its super easy not moderat i have 16 years old and i remove my keybord...
ZendomXGamer ZXG - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 17
Insgesamt: 5,112
