Einleitung
This guide will demonstrate how to replace the hard drive on your Latitude E5430.
  1. Slide the two notches outward. Lift the battery outward and pull.
    • Slide the two notches outward. Lift the battery outward and pull.
  2. Remove two Phillips head screws from the bottom cover.
    • Remove two Phillips head screws from the bottom cover.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Schon mal was repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Remove the four Phillips head screws from the hard drive caddy.
    • Remove the four Phillips head screws from the hard drive caddy.
    • System memory (RAM) is located here.
    • Low profile WLAN card
    • Various components can be replaced from this stage.
  5. Remove the four Phillips head screws surrounding the hard drive in the caddy.
    • Remove the four Phillips head screws surrounding the hard drive in the caddy.
    • There are two more screws on the other side of the hard drive.
  6. Congratulations, you've done it!
    • Congratulations, you've done it!
Abschluss
After you have installed your new hard drive or SSD, repeat the process in reverse.
Sam
270 Reputation
3 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 18
Insgesamt: 74
