Einleitung
This guide will demonstrate how to replace the hard drive on your Latitude E5430.
Was du brauchst
Slide the two notches outward. Lift the battery outward and pull.
Remove the four Phillips head screws from the hard drive caddy.
System memory (RAM) is located here.
Low profile WLAN card
Remove the four Phillips head screws surrounding the hard drive in the caddy.
After you have installed your new hard drive or SSD, repeat the process in reverse.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
