Zum Hauptinhalt wechseln
Dell Latitude E5470 Battery Replacement
Was du brauchst
  1. Dell Latitude E5470 Battery Replacement, Removing the Battery: Schritt 1, Bild 1 von 1
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift the battery away from the computer [3].
  2. Dell Latitude E5470 Battery Replacement, Remove the cable from the battery: Schritt 2, Bild 1 von 1
    • Unroute the cable from the routing channel [1] and remove the cable from the battery [2].
    • Connect the battery cable to the connector on the battery.
    • Route the battery cable through the routing channel on the battery
    • Insert the battery into the slot on the computer.
    • Tighten the screws to secure the battery to the computer.
    • Connect the battery cable to the connector on the system board
Abschluss
Marvin Romero
3.736 Reputation
32 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.989 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 25
Insgesamt: 607
