Zum Hauptinhalt wechseln
Dell Latitude E5500 RAM Replacement
Was du brauchst
  1. Dell Latitude E5500 RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 RAM Replacement: Schritt 2, Bild 1 von 2 Dell Latitude E5500 RAM Replacement: Schritt 2, Bild 2 von 2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 RAM Replacement: Schritt 3, Bild 1 von 1
    • The RAM sticks are located near the center of the device, and are arranged one on top of the other.
  4. Dell Latitude E5500 RAM Replacement: Schritt 4, Bild 1 von 2 Dell Latitude E5500 RAM Replacement: Schritt 4, Bild 2 von 2
    • Locate the two dislocating tabs on each side of the stick and place your fingers on the tabs.
    • Pull the tabs away from the stick to pop it out of place.
    • Notice the angle it rests at after the tabs have been opened. This is important for installation of new RAM.
    • Once the RAM stick has popped out of place, it can be gently removed.
  5. Dell Latitude E5500 RAM Replacement: Schritt 5, Bild 1 von 3 Dell Latitude E5500 RAM Replacement: Schritt 5, Bild 2 von 3 Dell Latitude E5500 RAM Replacement: Schritt 5, Bild 3 von 3
    • If necessary, repeat this process with the second RAM stick that lies beneath the first one.
Abschluss
To reassemble your device, install the new stick(s) and follow these instructions in reverse order.
4 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 2,205
