Was du brauchst
-Remove the sides on the back of the computer to take off the cover for the battery.
Disconnect battery cable from the connector and release cable from its routing channel.
Remove the screw that secures the battery and lift and push to remove the battery from the computer.
Tighten the screw to secure the battery to the computer.
Connect the battery cable to its connector on the system board.
Connect your computer and all attached devices to their electrical outlets.
Eine weitere Person hat diese Anleitung absolviert.
