Zum Hauptinhalt wechseln
Dell Latitude E5550-5550 Coin Cell Battery Replacement
Was du brauchst
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • Remove the battery, base cover, memory module, and hard-drive assembly, keyboard trim, keyboard [itself], palmrest, display hinge-brackets, display assembly, system fan, and system board from the computer.
  1. Dell Latitude E5550-5550 Coin Cell Battery Replacement, Disconnect & remove coin-cell battery.: Schritt 2, Bild 1 von 1
    • Disconnect the coin-cell battery cable from its connector on the system board [1].
    • Pry the coin-cell battery to release from the adhesive and remove from the system board [2].
    • Place the coin-cell battery into its slot on the system board.
    • Connect the coin-cell battery cable to its connector on the system board.
    • Install the system board, system fan, display assembly, display-hinge brackets, palmrest, keyboard [itself], keyboard trim, hard-drive assembly, memory, battery, and base cover for the computer.
Abschluss
Hezekiah Brown
6.169 Reputation
49 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
2 Kommentare
Do you know if it is possible to upgrade the motherboard during this processor
Chico Lopez - Antwort
Sorry for the late response. Yes; it's possible to upgrade the motherboard/system board during this process. You'll just have to check if the motherboard fits your Latitude E5550 as per the sources below.
(Main source: https://www.parts-people.com/index.php?a...
DELL Community source: https://www.dell.com/community/en/conver...).
Hezekiah Brown -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 470
