Zum Hauptinhalt wechseln
Dell Latitude E5550-5550 Hard Drive Replacement
Was du brauchst
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • Remove the battery and base cover from the computer.
  1. Dell Latitude E5550-5550 Hard Drive Replacement, Remove screws and cable.: Schritt 2, Bild 1 von 1
    • Disconnect the hard-drive cable from its connector on the system board [1] .
    • Remove the screws that secure the hard-drive assembly to the computer [2].
  2. Dell Latitude E5550-5550 Hard Drive Replacement, Remove hard drive assembly: Schritt 3, Bild 1 von 1
    • Remove the hard-drive assembly from the computer.
  3. Dell Latitude E5550-5550 Hard Drive Replacement, Release hard-drive cable: Schritt 4, Bild 1 von 1
    • Pull to release the hard-drive cable from its connector.
  4. Dell Latitude E5550-5550 Hard Drive Replacement, Remove screws to hard-drive bracket.: Schritt 5, Bild 1 von 1
    • Remove the screws that secure the hard-drive bracket to the hard drive [1] and remove the hard drive from the hard-drive bracket [2].
    • Place the hard-drive bracket on the hard drive to align the screw holders and tighten the screws to secure the hard-drive bracket.
    • Connect the hard-drive cable to its connector on the hard drive.
    • Place the hard-drive assembly into its slot on the computer.
    • Connect the hard-drive cable to its connector on the system board.
    • Tighten the screws to secure the hard-drive assembly to the computer.
    • Install the battery and base cover.
Abschluss
Hezekiah Brown
6.169 Reputation
49 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 843
