Einleitung
If your Dell Latitude E6230 is suffering from battery problems, use this guide to replace your battery.
Before using this guide, make sure that the problem with your laptop originates from the battery, as some issues with battery life can be due to other factors. There are multiple tools to check this, such as Windows's Battery Report.
Before beginning, make sure your laptop is not plugged in and is powered off. Step 4 of the guide will go over reinserting the battery. Take care to not force the battery in or puncture it in any way.
Was du brauchst
Flip the laptop over, so that the latches next to the battery are visible.
